Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Stop Document # Increment on Item Release
We use item documents to support our solidworks drawings in the following cases.
  • Purchased assembly manufacturer owns the CAD & drawing of the assembly.
  • Pneumatic/Cable Harnesses that are drawn in lucid chart and due to existing issue of PNGs being black after translation we cannot paste into solidworks drawing so we attach a PDF from lucid chart and refer to the document number in the solidworks drawing.
Our current workflow
  • Put document in “general documents” section of item
  • Write document number in SolidWorks drawing w/ the anticipated rev # change (ex: if currently at A → B)
  • Publish document
  • Release item
The problem w/ the current method is that the document # is not maintained throughout our process. Document number changes when the document is published ahead of the item’s release and then again when the item is released. Even if the document isn’t published ahead of the item’s release, the doc # still changes at item release.
I am requesting that the document number does not increment when an item is released.
2 Comments
vweaver_insulet
I had the same dilemma at my previous job. This has been an ongoing issue for years, going back at least to 2021.
tobiasSGVUM
I also was wondering, why the document Number is changing every time the item is released? This way it doesn't even make sense to have a document revision, due to having a new document number every time the item is releases, leaving us with Revision A always on the document.
This clearly should not work like this since it generates a lot of double files with the same content but different numbers, which leads to confusion in the end, if you search for files.
Since this behavior seems to be like this for a long time, is there any comment from Autodesk on this issue?
