Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
"eBOM-Current project" sub category under where used tab
Where used tab shows all projects despite user selecting a project from the project selection box following an advanced search/search. When an item is used in multiple projects, where used tab is useful. But user have to scroll thru complete list of projects in order to find out the required project and the multiple locations where the item was used in that specific project. Adding another category "eBOM-Current project" under the where used tab will allow user to navigate to all locations where the item was used under the current select project.
1 Comment
Status changed to: Gathering Support
Hi @smaddukuri2KE8C ,
could you please confirm whether this idea is the same as https://forums.autodesk.com/t5/upchain-ideas/where-used-feature-in-plugin-should-show-where-used-wit... and if there are some specific differences or different use case involved? Otherwise I would merge the two ideas.
Best regards,
Andreja Schneider
