Issue with Room assignment
marce.carta94
Message 1 of 12
marce.carta94
Hi there! After I've uploaded models into Tandem I've noticed that all of them are set to "Undefined" in the "Rooms" parameter, despite it's been compilated within Revit. How can I fix this issue? I want to correlate each asset to the room they're placed.
Thanks in advance!
Replies (11)
Message 2 of 12
jessica_smith
Hi Marcello,
Thanks for reaching out. If possible, could you provide some screenshots depicting how the rooms are set up, such as a room schedule and what you see in Tandem? For the room schedule, if you could include, at a minimum, the space/room name and type in the room schedule, that’d be helpful.
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
Message 3 of 12
marce.carta94
Hi Jessica,
Sure! On the left is depicted a snapshot of Revit, "Room name" and "Room type" are project parameters that I've set for you (I have the italian version of the software). Actually there are four models in Tandem (the snapshot is referred to ARC_0000_2020.rvt the architectural model), as you can see in "Source file", all them, except STR_0000_2020.rvt have rooms or spaces set.
Message 4 of 12
Niklas-Rouven.Wieczorek
Hi, I don't know whether the issue is still open, but I just wanted to mention that I'm in the same situation. Rooms are placed in all of our building models, but they show up in none of them in Tandem - instead, it just says "unassigned", exactly like in Marcello's example.
Message 5 of 12
jessica_smith
Hi Niklas,
Thanks for posting! Yes, this is still open. If you can send me screenshots like those I outlined in my previous reply, I can include them in the open case.
Jessica Smith
Message 6 of 12
Hi Jessica,
Thank you. I have included screenshots of our room schedule in Revit 2021. We use the German version of Revit, but you'll still be able to tell that every room is correctly placed, as indicated by various measurements (please note that for confidentiality  I have drawn a red shape over the 'names' column).
Importing the model into Tandem, however, only shows "unassigned" as the only option for spaces.
Message 7 of 12
jessica_smith
Hi All,
The fix for this has been pushed to production. For anyone who has spaces coming into Tandem as “unassigned,” reupload your models to Tandem to re-run the room assignment. If the problem persists, ensure that the models uploaded to Tandem contain the room definitions.
If this does not resolve the issue for you, please submit a support request and feel free to post questions or comments below.
Jessica Smith
Message 8 of 12
Hi Jessica, thanks for the update. I just updated the model and can report that I can now filter by space. Thank you!
Message 9 of 12
niteshpanchal
Hi Jessica,
I am not sure this topic is still open or not but even after reuploading the model i can not see room in my model. See attached screenshot for your reference.
Thank You!
Message 10 of 12
tsayenkoEXAVG
Hi Jessica,
I have the same issue here. I uploaded the model multiple times, but the rooms didn't appear. I also noticed that they are not present in the "Revit Categories" when I try to look at the "Inventory". Please advise.
Thanks!
Message 11 of 12
jessica_smith
Hello Everyone,
Thanks for posting and bringing this to our attention. I will look into this more and post any updates I have as they come. If anyone else is experiencing the same issue, as I mentioned above, please submit a support request here.
Jessica Smith
Message 12 of 12
owen677HJ
Community Visitor
Community Visitor
Hi @tsayenkoEXAVG and @niteshpanchal ,
I received an update that a fix for this has been pushed. Please refresh your model if possible and check to see that this is working.
If the issue persists, please submit a support case here.
