How to create a link parameter to link a document to specific asset?
Solved by AdamPeter. Go to Solution.
Here is a link to the help content. The interface needs a refresh, but the workflow is the same.
The key is to set the data type in the parameter to "Link".
tried this successfully in other element paramters, but when I try to add a second parameter to an element with a link - it doesn't work
Hi @brenttY9XRJ ,
Thanks for reaching out! Are you adding the second link to a second parameter or are you trying to copy/paste two URLs to the same parameter?
Thanks!
@brenttY9XRJ, can you provide me with a detailed outline of the steps you are taking to try and do this? Or a screen recording? If you don't want to post anything here, feel free to send me a private message with any attachments.
To add a second link parameter,
