Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Tandem Forum
Welcome to Autodesk's Tandem Forum. Please share your knowledge, ask questions, collaborate on ideas, and explore forum topics
Add parameter to link element to document
5 REPLIES 5
za.razali
883 Views, 5 Replies
How to create a link parameter to link a document to specific asset?
5 REPLIES 5
AdamPeter
in reply to: za.razali
Here is a link to the help content.  The interface needs a refresh, but the workflow is the same.
The key is to set the data type in the parameter to "Link".
Adam Peter
Customer Program Manager
brenttY9XRJ
tried this successfully in other element paramters, but when I try to add a second parameter to an element with a link - it doesn't work
jessica_smith
in reply to: brenttY9XRJ
Hi @brenttY9XRJ ,
Thanks for reaching out! Are you adding the second link to a second parameter or are you trying to copy/paste two URLs to the same parameter?
Thanks!
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
brenttY9XRJ
in reply to: jessica_smith
Jessica,
I'm trying to add a second parameter to the same element.
My intentions were to add to the element -
1.Specification [data sheet containing information regarding the element]
2.QA Checklist [pdf of commissioning checklist]
jessica_smith
@brenttY9XRJ, can you provide me with a detailed outline of the steps you are taking to try and do this? Or a screen recording? If you don't want to post anything here, feel free to send me a private message with any attachments.
To add a second link parameter,
  1. the second link parameter must be associated with the asset's classification in the facility template.
  2. When edits are made to a Facilities Template, such as adding more parameters to a class, you must click update under the Assets tab of the facility.
Jessica Smith
