Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
How do I take away the teleportation in Stingray/interactive?
2 REPLIES 2
574 Views, 2 Replies
Hi
in my application I want to have it so I don't have to use the teleportation (locomotion) I want to be able to walk around with a touch pad instead. (I keep getting advised to use an Xbox controller but it's for a client so its not ideal)
Any suggestions?
2 REPLIES 2
Shanii2
if a touch pad is of occulus or vive touch controllers. then u can easily extract motions or vector from the inputs as both of the controllers are supported just like how xbox i dealt with after which . you can just disable the functionality of teleportation if you opeup the unit of vive controllers.    The vive unit extracts the data of hand movements to move the , the controller units around in VR .  so you can also extract that same data to move ureself or HMD in the scene.
in reply to: Shanii2
Thanks @Shanii2  I'll give it a go and tell you the results.
