Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
Animation not importing into 3ds max interactive
4 REPLIES 4
donied
973 Views, 4 Replies
I have a basic door in max. I animated the door to open and close. I exported the the door to open and close. Exported the door to fbx. If I open the door in the Autodesk FBX Review i can see the door and animation. When I import the door fbx file into 3ds max interactive the animation does not import.
Any Ideas. I have attached the fbx file
4 REPLIES 4
donied
in reply to: donied
Anybody else come across this problem.
If I cant figure this out Interactive is not usable
francesco.torchia
in reply to: donied
Hi @donied !
Which version of 3ds Max Interactive are you using?
When importing the .fbx file, did you tick "Animation" in the Import FBX window?
Francesco Torchia
Technical Support Specialist – M&E (3ds Max, Maya)
francesco.torchia
in reply to: donied
Hi @donied!
I'm just checking in to see if you need more help with this.
Francesco Torchia
donied
in reply to: francesco.torchia
Thanks Thats it. I didn't see that check box
