Hi Everybody,
what am I doing wrong?
I open Sktechbook draw some lines press L (for Lasso-select )
define lasso-area
and then I try to move the selected lines
but the lines don't move they just stay where they are!!
HUH ?! What kind of unintuitive software is this?
Which hidden switches have to be turned around to make the moving work???
best regards Stefan
Solved by david.lau. Go to Solution.
You need to use the Quick Transform tool right afterwards. You can also use the Lasso tool in Quick Transform as well.
Thank you for answering the question. Aha. I understand. OK I made up my mind: I change to the software concepts. concepts fits better to what I call intuitive. https://concepts.app/en/
