SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
Lagging brush strokes after last update?
21 REPLIES 21
Message 1 of 22
8507 Views, 21 Replies
Hey. I just updated Sketchbook Pro when prompted and now every brush stroke is incredibly slow, no matter what brush. Using a smaller canvas doesn't help and my computer isn't running any other programs. It's too slow for the program to be of any use whatsoever. I'm using a Surface Book and my version of Sketchbook Pro is 8.5.
What can I do? Thanks in advance.
21 REPLIES 21
Message 2 of 22
I'm getting the same. Suddenly feels like a "chunky" piece of software, and not the swift, sleek software it's known for.
I've also spotted a bug - the colour palette won't always open since update to 8.5. (the Copic library does open)
It does look better, but functionality appears to have suffered. [Surface Pro 4 i5 4GB]
Tags (2)
Message 3 of 22
david.lau
Message 4 of 22
My wacom companion to is a stand alone with windows 10 installed on it and it has the brush lag, and this trouble shooting didn't work for me..
Message 5 of 22
I also have the same problem. I'm using a Microsoft Surface Book, drawing directly on the screen (i.e. NO Wacom) and just updated to 8.5. LAAAGGGGG! Brush strokes are terribly slow now. Unusable.
Message 6 of 22
david.lau
1. If you are the desktop version of SketchBook, try this:
Edit > Preferences > Uncheck the box "Enable Rotate"
2. You can uninstall SketchBook 8.5 and try the older version:
SketchBook 8.4.2 (32 bit)
https://autodesk.box.com/s/fioldjltjcv2acp39587p70psx6jex9q
SketchBook 8.4.2 (64 bit)
https://autodesk.box.com/s/z59y2z1zdqkjllm0r48srmu7ka9dx87s
Let me know if 8.4 works better or not.
3.  If you have a tablet (surface), can you confirm if the issue happesn in the Windows 10 version (Tablet)?
David Lau
Message 7 of 22
in reply to: david.lau
The older one fixed the problem, but what about future update and improvements?
Message 8 of 22
david.lau
I have PM'ed you to get some system specs.
David Lau
Message 9 of 22
Unchecking auto-rotation seemed to fix the issue, and I encourage all other users with this problem to give it a shot.
However, that's a functionality I use consistently as I draw. I don't feel I should have to sacrifice a core part of the program in order to make it usable. Is downgrading to an older version really my only option?
I can confirm that the issue works in Windows 10, in or out of tablet mode.
Message 10 of 22
Disabling auto-rotate seems to have fixed the  issue. Thanks for the suggestion. Luckily I don't really use the auto-rotate feature, but for those to do, do you plan to fix this problem in the next version?
Message 11 of 22
Whoops spoke too soon. Turns out I do use the auto-rotate feature. I thought it referred to the whole screen rotating when turning the actual tablet/computer (I'm on a Surface Book). Didn't realize it was the ROTATE feature in Sketchbook (what about it is 'auto' exactly?) So this is definitely not a fix for me, I always rotate my canvas.
BTW The Windows 10 version works just fine, no brushstroke lag.
I guess for now I'll be rolling back to 8.4 :S
Message 12 of 22
I am also going back to 8.4, using a Surface Book.
Message 13 of 22
david.lau
I have been getting lots of reports of some lag issues.  I am working with the development team to confirm and work on the issue.  At this time, the best workaround is using SketchBook 8.4.
David Lau
Message 14 of 22
I installed the 8.4 version from the link you posted. But large brushes still lag for me. Im using the desktop version on my surface tablet.
Message 15 of 22
This update has rendered the program unusable.  While the Windows 10 app is a stop-gap solution, it is not nearly as robust as the desktop version.  I tried to rollback but it would not allow me for some reason.  Trying another method to get the old version back.  This is on the Surface Book w/ Performance Base; I was excited for the graphical update but unfortunately I won't be able to use it until this issue is fixed.
Tags (1)
Message 16 of 22
david.lau
@Anonymous I would use Microsoft Fix it to uninstall SketchBook (Desktop version).
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
Then try this version:
David Lau
Message 17 of 22
david.lau
We just released SketchBook 8.5.1 and it appears to have resolved the issue.
See also:  https://forums.autodesk.com/t5/sketchbook-forum/update-8-5-1-solves-the-lag-issues/td-p/7485088
David Lau
Message 18 of 22
Will going back to the previous version delete all of my finished art, or will it keep all my drawings. The lag problem is also for android tablets,I use a Samsung tablet, so it isn't just for desktop.
It would also be nice if you could bring back the previous brush sets, the new ones are kind of confusing to try and find similar tools
Message 19 of 22
vfongwm
Hi zddfraser,
You should make a backup of your files before making any re-install of the app - see this article for instructions:
https://www.sketchbook.com/help/knowledge-base/back-files-settings/
Regarding brushes - the older brushes are still there but are now under the Legacy folder.
See this article for more brush information: https://www.sketchbook.com/help/knowledge-base/what-are-brush-types/
Basic and Legacy brushes (Mobile only)
If you have been using SketchBook since before the release of 4.0, you will notice a bunch of new brush sets, such as Texture EssentialsFine ArtHalf ToneArtist, and Pastel. One big change for you could be the Basic and Legacy brush sets.
Basic and Legacy brush sets in the iOS version of Autodesk SketchBook
Legacy is a new brush set, in name only. In the previous versions of SketchBook, the brushes now in Legacy where found in Basic. We moved them to make room for a new set of basic brushes that take advantage of our new texture technology. All your favorite brushes still exist. They’ve just been moved to Legacy.
Basic contains a whole new set of brushes that take advantage of textures. Try them out and see how close they come to the real thing!
Hope this helps.
Vivian
Message 20 of 22
in reply to: vfongwm
I still have lagging brushes occurring primarily since the 8.5.1 update. Everything lags. I tried uninstalling it and reinstalling it. No go. I reinstalled wacom drivers. No go. Then I noticed that the mouse input draws very fast with no lag no matter what size the brush is. The instant I switch to the wacom pen it lags like crazy. This does not happen in any other software (tested on photoshop and brush lag is non-existent).
Once I uninstalled and reinstalled 8.4.2 everything went back to normal and no lag whatsoever. So something is still amiss with the 8.5.1 update. So there seems to be some sort of glitch with how the wacom tablet vs the mouse interface process things for sbpro.
I am running win7 64 bit with plenty of power to do sbpro no problem - i7 3770 3.5GHz, 16G DDR3 ram, nvidia gtx 970, all HD are Samsung SSD.
