Solved by david.lau. Go to Solution.
Use the desktop version of SketchBook.
When you use the scale tool on the desktop version of SketchBook. the middle of the widget allows you to scale proportionally. You can use the spacebar to navigate the canvas.
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_tools_how_to_use_transforms_html
thanks for the fix David Lau. It is just annoying that it always seems the older/different/worse versions of software are the ones that are usually offered by Microsoft app store! The new 8.6 version looks vastly different - can't wait to test it out. Thanks again, T 🙂
