Greetings,
I'm working on a graphic that can be used for a video intro, and Sketchbook seems like a good tool for this. I've got a pattern that I want to trace and create a timelapse, but I'd like the trace image to be hidden in the final video.
Is there a way to make a layer not record when you use the timelapse function? Or is this something that would have to be done in a video editing software?
Solved by david.lau. Go to Solution.
At this time, there is no way to hide a tracing layer in the timelapse. It may need to be done in post but I am unsure on how to do it.
That's what I was thinking. Gonna try setting the color of the trace layer to the same layer as the video background. That might hide it.
Thanks for the response.
