I have question about the centre pivot in sketchbook pro…basically when using the quick transform tool, and selecting the centre icon to increase or decrease size and rotation tool to spin it round, it is dependent on the centre pivot that appears so that it rotate on that particular axis. HOW DO YOU CHANGE THE AXIS OF ROTATION IN THE FREE TRANSORM TOOL SO I CAN ROTATE FROM A DIFFERERENT PIVOT POINT, THERE MUST BE A KEY COMMAND IM MISSING, IVE LOOKED EVERYWHERE?!! In ps its just a case of moving it, with sketchbook, there must be way to move it.
Any advice or answer would be greatly appreciated.
Thanks.
Nick
Solved by david.lau. Go to Solution.
We don't have that option in SketchBook. I would log it as a new feature request here:
https://forums.autodesk.com/t5/sketchbook-ideas/idb-p/804
Hi Okay, Thanks. I could have sworn that i had moved the pivot point before in Sketchbook, but perhaps I'm getting mixed up with drawing software. yes it would be handy, i prefer sketchbook to draw in, it feels more natural and the right amount of tools for industrial drawing. but the pivot point would be handy for drawing mechanical parts so you can essentially, rotate to mechanisms back and forth so to speak. Thanks anyway.
