I have about 5 different sketches as I just started using Autodesk Sketchbook a few weeks ago. Almost all my sketches say "Failed to Open Image." Here are the factors:
-I always save my sketch before I close.
-All the images that won't open have had an imported image from my gallery
-When I look in my phone's files (internal storage>autodesk>sketchbook3) the .tiff files of the corrupt sketches don't appear, even though I never deleted them.
-Even using the "Save As" strategy, most of my drawings still get like this.
Any help is much appreciated. 🙂
I have seen this error a couple of times and I am uncertain of exact cause. I would save 'versions' of a file to make sure you don't lose your progress. See: step 7 noted here:
https://forums.autodesk.com/t5/sketchbook-forum/android-sketchbook-tips-and-tricks/td-p/9385407
I've also been having this problem using Autodesk app on my own android phone. I'm currently using version 5.2.3 of the app and whenever I try to upload a picture I saved in the gallery to work on it also gives me the Opps Fail to open image message. I also always save before closing the app or working on a new image and they are still saved in my phoes picture gallery, but whenever I try to load a wip or edit an older image to edit it I get the same notification. I also tried the tips suggested, but they don't seem to work.
Try this:
https://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_basics_back_files_settings_html
Go to the section:
