Application opens last project by default (in wrong res.)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
One of the things that I find the most disrupting is that when I start the application, it will often automatically open the last project I've been working on. However, it does not open it from it's saved file. Even though all the layers are there and everything looks correct, if I check the top of the screen it will list the project as "untitled" and if I check the image size, the width and height will be correct but the res. will be at 100px/inch. If I'm just the tiniest bit distracted (which I often am) I tend to either not realize this, or forget it, and I continue to work on the piece for quite a while. I realize it first when I try to save and it asks me to name my "new file". Since the program has opened my piece in 100DPI, this means that I can't even overwrite the original file (I always draw in 300px/inch) but instead I need to delete everything I've just done, open the original file and redo it.
As you can imagine, it's quite a hassle.
I have tried to check the settings but cannot find anything that I could adjust to make sure the program always opens a fresh canvas at start.
I'm working in desktop version 8.5.1 (win 10).
