problem with the Android app
hello,
I've been using sketchbook for about 5-6 years and after it became free for all there's this problem that keeps happening to the app on my android device.
after a while the app stops going to the gallery I can't make new sketches or view old ones, the only solution is to delete the app the Autodesk sketchbook folder and everything a and download it again, all my brushes and sketches get deleted every time.
is there any way to fix this problem permanently?
david.lau
Please try this:
https://forums.autodesk.com/t5/sketchbook-forum/sketchbook-crashes-on-android-when-opening-the-galle...
Deleting the /Autodesk folder will delete your sketches.  It will also allow SketchBook to be reset to default on first launch.
David Lau
yes, this is my problem. is there no way to stop it instead of losing all my preferences and gallery every few weeks?
david.lau
Hopefully, it will be OK after you reset SketchBook on Android the one time.
David Lau
its been like this for almost a year I think, I keep resetting it every time. so there's no solution to this problem other than that?
