02:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a very large structure supported on many springs. When the structure is loaded to its maximum weight the load shifts from the springs to ground after a 4 inch spring deflection. I want to model this in MES using 1D spring elements and grounded gap elements, where on one side of the gap is the structure and the other is ground. Ultimately, I should see the spring elements loaded to their expected force based on spring constant and displacement and remainder of the load as reactions on the ground plane. The structure was created in Solidworks and imported to MES so there is no "ground plane". Anyone know if MES has gap elements that can be specified between ground and the structure? If not any ideas as to how to model this in MES?
