Question
Question
Question
Hi, i´d like to ask something, i doing a simulation in mechanical simulation 2015, and what i want to do is the next:
I have a square block over a rectangular platen the distance between the block and the platen is about 1 mm, and i want to rotate the block on his gravity center and penetrade the platen and obtain the penetrade area involved.
I looked some tutorial about it but i didt´n found anything alike.
I tried to do a MES simulation but the simulation take to much time to get the results, so i think that i´m doing somethin wrong and just quit.
If somebody can help me i gonna be very gratefull...
thanks a lot
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
MES analyses can take a long time depending on the loads, velocity, and so on.
  • How long was the analysis running before you stopped it?
  • How many output steps did you receive? What were those results?
  • What have you tried to do to improve the analysis?
  • How are you trying to rotate the block? What is the load? What is the load curve?
  • If you delete the surface contact and just use a constraint to hold the block up, are you able to get it to rotate? In other words, is the difficulty with trying to rotate the block or the surface contact?
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
