Non-Linear MES analysis time duration issues
I am currently doing an non-linear MES analysis to see the factor of safety change over time. I wanted to run the test for at least 3 seconds. The test runs beautifully up until the 1 second mark then the animation stops. I couldn't provide a video cause the file size was too big, but I did provide pictures of the results at 1 second and a little after 1 second for comparison. I also attached a picture of my parameters.
Jim
If you need the video, I can maybe send it some other way.
marwan_azzam
Hello Jim,
You say that "the animation stops".  I'm not sure what that means so I will take a guess based on the results images you sent.
After 1 second the maximum safety factor jumps from 9.08 to  54.53 making it seem that there is no distribution in the results.  Am I correct?
Doe the analysis run to completion?
We would really have to look at the model so please post the archive file if possible.
Marwan Azzam
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
Do you have any update on this?
  • Did the analysis continue to solve for the entire duration?
  • What happens to the displacement and stress results for the time steps that you do have?
  • Does the load change after 1 second? Or stated another way, did you extend the load curve beyond the default input of 1 second?
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
