Hi @lihouxin065
I do not fully understand what this means: "I need to do a simulation task to get the time-varying curve of the average strain of the sensitive area of the strain-type load cell that supports the conveyor belt frame during the conveying process of the conveyor belt". I am not convinced that you need to perform a full MES analysis where you try to simulate the physical motion of the belt.
Stated another way, what effect does the rotation of the rolls and motion of the belt have on the "sensitive area"? Is there a faster way to simulate the effect without going through the time (and trouble) of moving the rolls and belt?
The driven roll is not rotating at 10 rev/sec because it takes a lot of force to accelerate a 26 N roll from 0 rev/sec to 10 rev/sec over a time period of 0 seconds. (Answer: it takes an infinite force for an infinite acceleration.) There is not enough friction in the belt to do that! The results show that the belt is slipping on both rolls.
Assuming you do not use an alternative method to simulate the loads, then
- If the start-up of the rolls is important to the analysis, then you should accelerate the driven roll from 0 to 10 rev/sec over a time period of T.
- If the start-up of the rolls is not important, then you should give the rolls an initial angular velocity ("Setup > Loads > Initial Velocity") and give the belt an initial velocity. (You would need to split the belt into 4 parts to give a -X velocity to the top, +X velocity to the bottom, and angular velocity to the half wrap.)
Unless the belt is a thick piece of plastic that resists bending, I suggest that you use membrane elements for the belt. Membrane elements have no resistance to bending. They only have tension loads. (By using bricks and a plastic material, the stress required to bend and unbend the belt will not be realistic.)
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
