Wind Simulation on Dome
jacobusJBFYP
jacobusJBFYP
I want to run the wind load simulation on a silo with a domed roof. When I create an arc and then revolve it, even though I can mesh it, the wind load simulation ignores it. Creating a hopper using the cone command works with the wind load simulation as well as a sphere.
Any way of creating a dome in Robot that will be recognized by the wind load simulator?
Stephane.kapetanovic
hi @jacobusJBFYP
try reading these topics
https://forums.autodesk.com/t5/robot-structural-analysis-forum/create-a-dome-structure/m-p/11541835
https://forums.autodesk.com/t5/robot-structural-analysis-forum/load-wind-to-arc-dome/m-p/3840736
could you show us some views of your model or share it with us?
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
jacobusJBFYP
Thanks a lot. That is not quite what I am looking for.
I want to model a dome using the Revolve command in such a way that the Wind Simulation works.
hi @jacobusJBFYP
Have you tried modelling the silo from a polyline with a line and an arc using the revolve command ?
Best Regards
jacobusJBFYP
That is exactly what I want to achieve. I just found that even when following that workflow, somehow the dome is ignored.
I've been testing it all out this morning and found that I just need to tick the New object option when using the Revolve command. It works perfectly then.
