One way spanning slab
Tmanzz
Tmanzz
Can someone kindly assist with the attached model?
I am trying to get the slab to span in just one way but it appears to be distributing the loads in 2 ways.
Please advise the best way to do this.
It has been modelled as a plate.
Thank you
DennisVDijk
Hello Tmanzz,
You can set the reinforcement in one way, see below:
results:
model attached.
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Tmanzz
Hi @DennisVDijk
Thanks for that explanation.
Unfortunately can't open the attachment. Not sure why.
Can you resend as a Robot file please?
DennisVDijk
I Attached a new ZIP file. I is not possible to attach RTD file.
Kind regards,
Dennis van Dijk
Structural engineer
Tmanzz
Hi @DennisVDijk
Thanks for that. I have been able to open it.
As a one-way spanning slab is it possible not to have any moment in the YY direction?
Ideally I want all the moment to be along the long span xx.
This is a precast slab spanning in the longer direction.
DennisVDijk
@Tmanzz,
If You use shell than there will always be moments perpendicular to the main direction, but with orthotropic you can reduce this:
If you don't want the benefit of a shell model you should model it as a beam.
results:
model attached.
TIP: mesh-size equal to the thickness of the slab 😉
Kind regards,
Dennis van Dijk
Structural engineer
Tmanzz
thank you
