when i try to identify the loads then its freezing (robot 2020)
Slman890
Observer Observer
Slman890
Observer
Observer
Dear all
as per the subject, I try many times in different Pcs but unfortunately it still freezing since I click the load type icon
please find the attached screen shot file below,
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Slman890
Try the following
  • check and if necessary update RSA 2020 with SP1   can be downloaded here SP1
  • open file in Repair mode (File >Open>Check repair mode button while file opening
  • clear user profile settings (delete the following folder
C:\Users\%username%\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2020
Check after each step if it helps
Krzysztof Wasik
