coppy of nodes and load cases
Message 1 of 10
hello, I need urgent help for my thesis. In my model, I define some nodes and loads on them. I don't know how to copy those nodes and loads together to all remain floors.
all load cases and their locations( nodes) should be copied as in exactly same form.  please help me. thanks
Accepted solutions (3)
Replies (9)
Message 2 of 10
Simau
Hi @Anonymous
Select the nodes you want to copy then
Nodes with their loads will be copied
M. Agayr
Message 3 of 10
it is copied only for the second floor. but for other floors, nodes and loads cannot be copied for some reason. I could not figure it out.
when I try to copy everything to the third or fourth floor, there is no any node or load.
Message 4 of 10
Simau
if the floor height is the same you can copy the nodes at once by specifying the number of repetitions
M. Agayr
Message 5 of 10
hello,
I need very urgent help. I designed a car park model and defined some specific nodes and loads to show speed bumps. When I try to copy the nodes and loads on the first floor, it only works for the second floor. Other floors don't show any force or load. Please help me. My model is attached.
Message 6 of 10
Although the heights are the same, it does not work on other floors. If you have a chance, could you try and see it? I will be appreciated for that.
Message 7 of 10
Simau
Model with loads copied attached
M. Agayr
Message 8 of 10
paul.bassLH
Hello @Simau ,
What was wrong with this model ? We can only select panel from lvl+4.0 but not others?
When i try to copy node from lvl+4.0 to lvl+8.0, nodes are not copied. Something with definition of stories ?
Thx
Message 9 of 10
Simau
Hi @paul.bassLH
I no longer remember the different modifications I made:
- deleted axis
- created floors then deleted them
then finally it worked 😊
M. Agayr
Message 10 of 10
Thank you so much! You literally saved my life 🙂
It is so good now!
