Slab reinforcement cover
JPNR87
JPNR87
according to Eurocode nominal cover (for calculations):
In Robot is cover defined:
For example hand calculation demands nominal cover 25 mm (10mm deviation+15mm minimum cover for plate calculation).
My question is how nominal cover for plate design is calculated and inserted in Robot to have 25 mm nominal cover ?
Thanks for answers!
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @JPNR87
While slab reinforcement parameters definition cmin is defined on reinforcement tab
and dcdev is defined in Deviations window
Then cover taken for calculation is c=cmin+dcdev.
So to define cnom 25 mm you should define c=15 mm then dcdev=10 mm
Krzysztof Wasik
JPNR87
Hi!
opening this threat once more with additional question.
In case of two-way working slabs how does Robot consider lever arm for none-main rebar. For example if I have slab with Cnom= 25 mm with 10 mm rebars does Robot consider automatically c2=25+10+10/2.
Thanks for answers!
