Restricts on RSA
Restricts on RSA
Restricts on RSA
I wonder that; is there any restricts on RSA? For example; if you do analyse with sap2000 there is some limitations on edu version. if you do nonlinear analyse;you can analyse system up to 30 joints or for normal analyse you can use 100 joints. Is there a similar limitations on RSA? Or, is there  any other limitations for analyse in normal versions?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
There are no restrictions for analytical options imposed on either Robot Structural Analysis educational, or 30 days trial version.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
