Two way cladding does not consider opening
4 REPLIES 4
nali_ameen
219 Views, 4 Replies
I am trying to distribute loads from a cladding (with two opening) to beams. the 1st opening behaves as expected as it skips load distribution in the opening area. But, the 2nd opening is not working as expected as shown in the load distribution regions below.
Attached is my model.
Thank you
4 REPLIES 4
Rafacascudo
in reply to: nali_ameen
I see 2 options .
1- redo de opening contour avoiding touching the cladding edges as I did in the picture or
2- redo the cladding contour including the openning "rectangle" into it and also creating a small triangle cladding in the botton left
Rafael Medeiros
nali_ameen
in reply to: Rafacascudo
Thank you Rafael, I tried the 1st option and worked.
Simau
@nali_ameen
Did you check BM after correcting roof claddings as suggested by @Rafacascudo
M. Agayr
nali_ameen
in reply to: Simau
yes, I have checked the BM and it wasn't correct. But, offsetting the opening little bit from the edge has solved the load distribution issue.
