I am trying to distribute loads from a cladding (with two opening) to beams. the 1st opening behaves as expected as it skips load distribution in the opening area. But, the 2nd opening is not working as expected as shown in the load distribution regions below.
Attached is my model.
Thank you
Solved by Rafacascudo. Go to Solution.
I see 2 options .
1- redo de opening contour avoiding touching the cladding edges as I did in the picture or
2- redo the cladding contour including the openning "rectangle" into it and also creating a small triangle cladding in the botton left
Rafael Medeiros
Did you check BM after correcting roof claddings as suggested by @Rafacascudo
M. Agayr
