Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Torsion Moment of Inertia resulting 0
2 REPLIES 2
hvelasquezmast
155 Views, 2 Replies
Could anybody help me guessing why the model computes Ix = 0 for the highlighted section type?
If I consult the details of the aforementioned section a little closer, the Ix equals 25,537,485 cm^4 and is different from 0.
The actual .rtd model can be downloaded for inspection from
https://drive.google.com/file/d/1y23NLaexDsMoGJp1er0NKzT8AAiG74Dp/view?usp=sharing
I'd greatly thank whoever wishes to share some of his(her) valuable time with me about this.
Hernan
2 REPLIES 2
Hi @hvelasquezmast
Such section sould be saved in User section database before using in the model.
Actually there Ix=0 in section properties used for calculations.
Check section properties in User section database (correct Ix if necessary) then reload section to your model.
Procedure for updating section data in user database is presented in solution part
Edit user section database and update required values manually for already defined sections (then reload section to model)
in the following article.
Missing properties of steel section while code check according to EC3
Check section properties in us
Krzysztof Wasik
Thank you very much, Krzysztof. Have a good weekend
Technology Administrators
