Could anybody help me guessing why the model computes Ix = 0 for the highlighted section type?
If I consult the details of the aforementioned section a little closer, the Ix equals 25,537,485 cm^4 and is different from 0.
The actual .rtd model can be downloaded for inspection from
https://drive.google.com/file/d/1y23NLaexDsMoGJp1er0NKzT8AAiG74Dp/view?usp=sharing
I'd greatly thank whoever wishes to share some of his(her) valuable time with me about this.
Hernan
Solved by hvelasquezmast. Go to Solution.
Solved by Krzysztof_Wasik. Go to Solution.
Such section sould be saved in User section database before using in the model.
Actually there Ix=0 in section properties used for calculations.
Check section properties in User section database (correct Ix if necessary) then reload section to your model.
Procedure for updating section data in user database is presented in solution part
in the following article.
Missing properties of steel section while code check according to EC3
Check section properties in us
