Tips and tricks in Robot
Artur.Kosakowski
Autodesk Support Autodesk Support
Message 1 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm starting a new topic where we can share all the smart ideas for making a model faster, finding mistakes easier or design something that seemed impossible with others.
Let me start with the link to the Build Your Robot Structural Analysis IQ! - Tips and tricks in Robot webinar.
Artur Kosakowski
Replies (38)
Message 21 of 39
Really i need this
Message 22 of 39
abidlihouda
Hi @Artur.Kosakowski
Thanks a lot !
Message 23 of 39
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
Rescaling  \ stretching model by Transformation of Coordinate System.
Rafal Gaweda
Message 24 of 39
Great!
Thank you @Rafal.Gaweda.
Wassim
Message 25 of 39
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 26 of 39
abidlihouda
Thanks a lot.
Message 27 of 39
Hi there,
It appears that I'm unable to add X and Y direction nodal forces direction to Plate elements which have been used to model slabs/raft foundations (please see attached screenshot). Is there a tip or trick you can provide which would help solve this problem? I guess it would be used primarily to check that a foundation has adequate resistance to the sliding failure mechanism.
Any help would be greatly appreciated!
Owen
Message 28 of 39
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 29 of 39
Thank's so much!
Message 30 of 39
Sorry to bother you once again - the horizontal forces I'm applying to the slab are representative of the horizontal reactions from the superstructure, which are applied to the top surface of the foundation. These would then, therefore, have an effect upon the bearing stresses beneath the foundation due to the moment created (Fx or Fy multipled by the depth of the foundation) - does the analysis take this into consideration? Or should this effect be accounted for by applying a concentrated moment in addition to the horizontal force?
Thank you.
Message 31 of 39
fareed12
Is possible to calculate Torsional Amplification factor (Ax ) by dynamic forces from (Response Spectrum Analysis) or need to make procedures to do it?
Message 32 of 39
fareed12
Hi good day Is possible to calculate Torsional Amplification factor (Ax ) by dynamic forces from (Response Spectrum Analysis) or need to make procedures to do it?
Message 33 of 39
saclovitzky
That's a great video Mustafa. How about cutting any arbitrary shape within the boundary of a curve wall(with specified dimensions).Pls. see attached.
Message 34 of 39
EnricoCorvaglia
it would be interesting a suggestion on how to verify a node of an RSA beam frame in a software like Inventor and Nastran ... as asked in another post .... two Autodesk software ... to have support in this from autodesk agents would be as much as less desirable
Message 35 of 39
halvarezg
Observer
Observer
Hello, I have a series of doubts.
What benefits does ROBOT have besides the ease of interaction with REVIT compared to other analysis software such as MIDAS, SAP, ETABs?
Does the purchase of ROBOT also include something additional such as a license for REVIT or something that makes it more attractive economically?
Message 36 of 39
Romanich
Hi @halvarezg ,
Robot is a part of the AEC Collection and can not be purchased separately.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 37 of 39
LeeCastro
Be more productive by set layouts stored in history and activating them at any time.
Follow the steps below::
a. After set a layout that you need, go to the View menu (1) and History (2)
 b. Your last action will appear in the list of views and will be without a label (<No Label>), select this line (3), write a title of your choice (4), press enter key to confirm (5)
c. Repeat steps (3) to (5) ow many times you need.
d. Click the box to enable "Show only labeled views" (6) and you can now browse your custom layouts (7).
e. You can choose to leave this floating tab open, or if you close it, simply repeat steps (1) to (2).
f. To create new custom layouts, don't forget to disable step (6) and repeat steps (3) to (7).
That'a all!
Marque Aceitar como Solução e clique em Curtir.
Select Accept as Solution and click on Like
Li Chong Lee, DSc.
LinkedIn Instagram | Facebook | Twitter  | YouTube
Participante da Comunidade de Usuários Autodesk Brasil
Message 38 of 39
CaioSaporito
CHANGE ORIENTARION EASILY (PRINTOUT COMPOSITION)
This trick that is taught in the Printout Composition Webinar. Very useful to change the orientation of any page.
Best regards,
Caio
Message 39 of 39
WALIDGIO
thank you
