Tips and tricks in Robot
Artur.Kosakowski
Autodesk Support Autodesk Support
Message 1 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm starting a new topic where we can share all the smart ideas for making a model faster, finding mistakes easier or design something that seemed impossible with others.
Let me start with the link to the Build Your Robot Structural Analysis IQ! - Tips and tricks in Robot webinar.
Artur Kosakowski
Replies (38)
Message 2 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
Editing model (e.g. changing frame bay spacing) by moving structural axes
Artur Kosakowski
Message 3 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
Checking for gap between elements
Courtesy of @mustafahesenow (thank you for the inspiration for this topic)
Post 6 from https://forums.autodesk.com/t5/robot-structural-analysis-forum/checking-for-gap-between-elements/m-p...
Artur Kosakowski
Message 4 of 39
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 5 of 39
Muhammed.OPERA
Very useful topic, thank you for posting that @Artur.Kosakowski.
I'll be very thankful if you upload the full video that you corrected my model in.
and for you @mustafahesenow , we still waiting for your next video eagerly.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 6 of 39
mustafahesenow
Hi @Muhammed.OPERA
Hopefully today Smiley Wink
Mustafa Hesenow
LinkedIn
Message 7 of 39
teixeiranh
The Skyline Algorithm to check Instabilities type 3! Love it!
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Message 8 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Muhammed.OPERA
All was actual covered during the 2nd RSA webinar: Smiley Happy
1. Correction to structural axes and indicated vertical planes
2. @mustafahesenow video to determine short elements so that you can merge the very close located nodes in the model created after operation in the point 1 above
3. Meshing with the regular mesh switched of
Artur Kosakowski
Message 9 of 39
Great video @mustafahesenow , I actually was more impressed by how you manage the windows and move them into the ribbon. There are no such videos for small efficiencies. One I love is using Alt + E + E + M to quickly initiate the copy and move command. I was surprised that you sound like such a young man Mustafa Man Surprised I expected you to sound like one of my university professors. Smiley Wink
Message 10 of 39
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 11 of 39
Grohl
VBA code to replace envelope values with >> or << copied to Excel. Makes the replaced cells bold as well.
Sub Replace()
'''REPLACE SOMETHING IN CELL'''
Dim rngStartCol As Integer
Dim rngEndCol As Integer
Dim rngStartRow As Integer
Dim rngEndRow As Integer
Dim rngUsed As Range
Dim rngActive As Range
Dim rngReplace As Range
Dim strToReplace1 As String
Dim strToReplace2 As String
Dim strReplaceWith As String
Dim cell As Variant
'Finner startcelle og sluttcelle
If ActiveCell.Value <> "" Then
    rngStartCol = ActiveCell.End(xlToLeft).Column
    rngEndCol = ActiveCell.End(xlToRight).Column
    rngStartRow = ActiveCell.End(xlUp).Row
    rngEndRow = ActiveCell.End(xlDown).Row
Else
    MsgBox ("Blank cell chosen")
    Exit Sub
'''Velger range basert på ytterste celler
Set rngUsed = ActiveSheet.Range(Cells(rngStartRow, rngStartCol), Cells(rngEndRow, rngEndCol))
Set rngReplace = rngUsed
strToReplace1 = ">>"
strToReplace2 = "<<"
strReplaceWith = ""
For Each cell In rngReplace
    If InStr(cell.Value, strToReplace1) > 0 Then
        cell.Font.Bold = True
    ElseIf InStr(cell.Value, strToReplace2) > 0 Then
Next cell
rngReplace.Replace strToReplace1, strReplaceWith
rngReplace.Replace strToReplace2, strReplaceWith
End Sub
Message 12 of 39
Excellent topic! I've been looking for something like this since i'm just starting to use RSA.
I wonder, is there a way you could post some tips for complex geometry? Or point me to a source i can find it.
Thanks in advance!
Message 13 of 39
Muhammed.OPERA
Very very good my friend @mustafahesenow Smiley Happy
Thank you.
Facebook |LinkedIn
Message 14 of 39
mustafahesenow
Welcome.
Mustafa Hesenow
LinkedIn
Message 15 of 39
teixeiranh
Quick trick to deal with windows:
assign a shortcut for the tile command, like "SHIFT+W"
Message 16 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
How to define an ellipse:
Artur Kosakowski
Message 17 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
How to extrude bars into walls
Artur Kosakowski
Message 18 of 39
You, sir, have saved my life.
Thank you very much!
Message 19 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
Smiley Happy
Artur Kosakowski
Message 20 of 39
Artur.Kosakowski
Autodesk Support
Autodesk Support
Selection by a circle
Artur Kosakowski
