Different ratios for member and group verification
ewu168
ewu168
load type of Wind load.pngMember and Group verification result different.png
Hi Artur,
In this pylon model, pls help to looking into following problems:
  1. In the first screenshot, what shall I specify the "Load Type" for the wind load..."Uniform" or "(FE) Uniform"? what is the difference?
  2. In the second screenshot, I'm getting "Section error" in "Member verification", while "Section OK" in "Group Verification"...why Robot gives out different result?
Pls find the Robot file as attached,
Regards
Eric
@ewu168 Artur Kosakowski edited the topic for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Eric,
The prior is the bar type load whereas the later applies to surfaces
The prior was launched for both ULS and SLS and failed for serviceability whereas the later for ULS only.
Artur Kosakowski
ewu168
Thank you Artur, I got it now 🙂
Regards
Eric
