support uplift
support uplift
saclovitzky
Message 1 of 12
support uplift
saclovitzky
Pls. see attached file. I am just wondering why I have an uplift on props nos. 6 & 8? It is only carrying SW of the slab?
Any help will be greatly appreciated.
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @saclovitzky
The first thing is to look at the deformation:
This is why the load takedown approach is not applicable for a models with more complex static schemes.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 3 of 12
saclovitzky
@Artur.Kosakowski
What do you mean Artur?So literally there's no uplift?The reason why I model this, is to actually see what actual loadings will go for the middle props(as only 2 props are allowed!)
Message 4 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @saclovitzky
I don't understand what you mean. My point was that if you would calculate reactions (forces in the columns) based on the tributary area you would see no uplift which exists in reality.
Artur Kosakowski
Message 5 of 12
saclovitzky
Thanks Artur for your reply. Taking the weight by tributary area is the simplest way to get the reactions in every floor level(just multiply it by 5 , but I am getting huge loads and 2 props are not enough). What I am trying to do is to model the whole lot and see what actual load these 2 middle props are getting(capacity per prop =73 kN). In so doing, I didnt realize that the other 2 props are getting uplift. If I isolate a single level of slab there's no uplift but you need to multiply it by five to get the total reactions, and the loads on the middle props will exceed its capacity. I am just wondering whether I represent the model of props correctly(ie, I mean do I need releases on their connection?)
Message 6 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @saclovitzky
The use of releases depends on the connection type. If they don't transfer bending you should define them.
Artur Kosakowski
Message 7 of 12
saclovitzky
@Artur.Kosakowski how can I model the props(column) just for axial loads only(is this the "pinned-pinned" releases?)
Message 8 of 12
saclovitzky
@Artur.Kosakowski
Is there any chance that I can remove the uplift on the said props. Is there any "releasing" connection technique that can eliminate this uplift?
Message 9 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @saclovitzky
You can define them as compression only bars.
Artur Kosakowski
Message 10 of 12
saclovitzky
Thanks Artur but why it takes so long to converge?
Message 11 of 12
Simau
@saclovitzky
To avoid upfilt, you can add linear release from either sides of the central beam.
Before doing that you have to create 2 pannels by story.
M. Agayr
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @saclovitzky
This is due to the fact that Robot has to determine which of the compression only bars are active (under compression) and which should be switched off (when in tension) with each load increment which requires calculations of the whole model at each of the iteration.
Artur Kosakowski
