Thanks Artur for your reply. Taking the weight by tributary area is the simplest way to get the reactions in every floor level(just multiply it by 5 , but I am getting huge loads and 2 props are not enough). What I am trying to do is to model the whole lot and see what actual load these 2 middle props are getting(capacity per prop =73 kN). In so doing, I didnt realize that the other 2 props are getting uplift. If I isolate a single level of slab there's no uplift but you need to multiply it by five to get the total reactions, and the loads on the middle props will exceed its capacity. I am just wondering whether I represent the model of props correctly(ie, I mean do I need releases on their connection?)
