Fixed Support Option in RC Beam module
MUHANNAD.ABU_ABDO
MUHANNAD.ABU_ABDO
i'm wondering why there's no fixed support option in RC Beam Design module ?
Only available pinned or roller ?!
Thanks in advance
Artur Kosakowski edited the topic for better findability and marked the post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Muhannad M.Abu Abdo
Structural Design Engineer
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @MUHANNAD.ABU_ABDO
it should be available after you expand the type list:
If it isn't could you attach the file?
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Mohamed.E.Salem
HI @MUHANNAD.ABU_ABDO
you can choose support type ( span geometry tab)
MUHANNAD.ABU_ABDO
Thanks Arthur i found a way to design the beam directly using RC Elements module
Muhannad M.Abu Abdo
CaioSaporito
Hi @Artur.Kosakowski and everyone!
When I export a beam to Design module, the option "fixed" doesn´t appears to me (only pinned e roller).
In my simple model there are 2 columns e one beam with no releases.
When I see the diagrams  and the reinforcement generated in Design Module, seems Robot compute the negative moment on supports but it´s unconfortable not have the option "fixed" in spam geometry.
This option only appers when i creat a beam directly in RC Design model.
How can I solve this?
Thanks in advance.
brisid.isufi
Same issue here, in 2024. When I create the beam from a model, I don't have the option for a fixed support.
