isolated node cannot be found and calculation warnings and errors
nkosana.ndlovu
nkosana.ndlovu
Greetings,
I am new to Robot Structural Analysis and i have been modelling a building. When i verify it, I get a warning of an isolated node. See the attached picture. I have tried following advice in these links: how to remove isolated nodes, with no success.
When i proceed to calculation, i get the isolated nodes and "linear load has not been applied to a panel," as well as the error, "the element is defined outside the geometric limits of the assigned story. See the attached photo.
I don't understand why the other warnings were not picked up during verification. I also don't know where I am making mistakes in modelling the structure. I have attached the file here as well.
Please help
Hi @nkosana.ndlovu
You can notice that your model is having alot of inaccuracies, remove the meshing and the cladding and make the nodes visible so you can fix these inaccuracies.
nkosana.ndlovu
Thank you, let me try that
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @nkosana.ndlovu
Try to define (more) structural axis along the walls and in the planes of the columns and then use Edit > Detailed Correct options with the adjustment to them with precision set as e.g. 0.1 m.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
