Hi
Would anyone be able to help me. Have not been involved with Robot to long and I have a question regarding the steel design Results.
I have run the Code group Design and applied the changes, Then ran the Code Group verification, and again all is OK. Then Ran the Member verification and all members is OK. But if I Select one of the the Rafters in the middle part of the building and select object properties and Code check It says incorrect section as per my image attached. Can someone please help me understand why all the calculations showed OK but if I goto the Object properties, it says incorrect section.
Thanks very much
I had a similar issue. You can see my discussion below:
