Dear all,
I've come across a strange issue in the following model: https://we.tl/t-19pblG7jMW. When I run a code check for all bars, some bars are skipped (e.g. bar no. 4 and 17). But when I run the code check specifically for these bars, I get correct results, they are no longer "skipped". See attached screenshots.
What could be the issue here? I think it's a big problem if the user thinks they have run a code check for all bars and the structure is OK, when in reality a few bars were excluded from the check.
Thanks for the help in advance!
Best regards,
Marcell
Solved by Rafal.Gaweda. Go to Solution.
Hi @Rafal.Gaweda ,
Thanks for the quick solution!
Do you know how to implement this in API? As in, how to make sure the components of complex bars are included in the code check? An API code check returns an error when it comes to checking bar no. 4, if I run it for all bars.
Best regards,
Marcell
