Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Code check: skips bars when "all" is typed, runs fine when bar no. is typed
3 REPLIES 3
412 Views, 3 Replies
Dear all,
I've come across a strange issue in the following model: https://we.tl/t-19pblG7jMW. When I run a code check for all bars, some bars are skipped (e.g. bar no. 4 and 17). But when I run the code check specifically for these bars, I get correct results, they are no longer "skipped".  See attached screenshots.
What could be the issue here? I think it's a big problem if the user thinks they have run a code check for all bars and the structure is OK, when in reality a few bars were excluded from the check.
Thanks for the help in advance!
2019-03-06 08_42_19-Autodesk Robot Structural Analysis Professional 2018 - [View - Cases_ 1 (DL1_ De.png
Best regards,
Marcell
3 REPLIES 3
Rafal.Gaweda
Hi @Anonymous
Rafal Gaweda
in reply to: Rafal.Gaweda
Hi @Rafal.Gaweda ,
Thanks for the quick solution!
Do you know how to implement this in API? As in, how to make sure the components of complex bars are included in the code check? An API code check returns an error when it comes to checking bar no. 4, if I run it for all bars.
Best regards,
Marcell
Found it: I_DCCFT_INACTIVECOMP = 1
