Steel Design module and Code check tab of bar properties show different ratio
I'd like to know why I'm seeing an inconsistency in my project? Shouldn't these values be the same? File is attached if needed to look at it.
@Anonymous Artur Kosakowski edited the topic for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check:
ROBOT - Steel Design module and Code check tab of bar properties dialog show different values of rat...
Artur Kosakowski
Thanks Artur,
However, I do find it puzzling as to why this method is implemented into RSA as it can be a bit misleading since it shows to me that the ratio was calculated based on the CSA S16 code in both menu boxes.
Artur.Kosakowski
Autodesk Support
Autodesk Support
On request of users making such quick check / section size estimation for very simple structures (they did not want to enter the steel design module at all).
Artur Kosakowski
Just a follow up on this issue:
I even encountered an issue like this which can cause even more confusion.
Note: This is for a different project and not the same as the OP.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If this make you feel better I voted for removing this tab for exactly the same reason you described but as I explained there were other reasons to keep it as it is Smiley Sad
All I can suggest is not to use it as you already know what its limitations are.
Artur Kosakowski
No problems Artur Smiley Wink
Just wanted to make sure you were aware of it but glad to see that you already knew it Smiley Happy
