- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
I have a problem with Robot that I cannot solve.
It occurs since yesterday and today I've updated to the last version but nothing solved.
The problem is that when I try to create a new shell structure, for example defining a squared steel panel, and try to mesh it rather than getting this menu (wich I got usually before)
I get this one
The strange thing is that this happens when I try to make a model from cero. When I open an old model already meshed and try to change meshing properties, It works, but as soon as I execute meshing (local or global) command again, system fails again and go back to the same problem. Seems like if I cannot asign the shell propertie to a panel.
Could you please help me.
Cheers.
