Shell Meshing Problem
Hello.
I have a problem with Robot that I cannot solve.
It occurs since yesterday and today I've updated to the last version but nothing solved.
The problem is that when I try to create a new shell structure, for example defining a squared steel panel, and try to mesh it rather than getting this menu (wich I got usually before)Menu 1.jpg
I get this one
The strange thing is that this happens when I try to make a model from cero. When I open an old model already meshed and try to change meshing properties, It works, but as soon as I execute meshing (local or global) command again, system fails again and go back to the same problem. Seems like if I cannot asign the shell propertie to a panel.
Could you please help me.
Cheers.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Thanks.
Now works but... what's the difference? When shoul turn it on?
Regards
Thanks.
Very useful.
Cheers.
