List of Revit link improvements in 2013 version
Is there a list of improvements made to the Revit link in the 2013 version available?
Artur.Kosakowski
Autodesk Support
Autodesk Support
See the page 5.
Artur Kosakowski
I was thinking about a more detailed list, including bug fixes and minor enhancements.
With those two features listed in the attached document there is no way I will convince anyone to an upgrade.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Patrick,
The improvements and corrections apply to the following issues:
Transfer of material for families already loaded in a project for models updated from Robot
Thickness of orthotropic panels exported from Robot to Revit
Joists and joist material imported from Revit to Robot
Import of structural axes from Revit to Robot
Steel type labels for bi-directional transfer of models between Revit and Robot
Bar linear load transfer from Revit to Robot and from Robot to Revit
Export of rotated bars from Robot to Revit
Export of large models from Revit to Robot
Internal forces import from Robot
Tapered column import from Robot
Meshing parameters for bi-directional Robot to Revit model transfer
Required reinforcement import from Robot
New material creation in Robot for model exported from Revit
Material properties in Revit for models exported from Robot
Export of double channels sections from Revit to Robot
in addition: Correction of lack of possibility of exporting models from Revit to Robot when About dialog is opened in Robot
Artur Kosakowski
