Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
selection of walls to Story
3 REPLIES 3
saclovitzky
310 Views, 3 Replies
In creating story levels, I'm just wondering why some of the walls are left out.
Is there a way to include them afterwards.
Pls. see attached screenshot and file regarding my queries.
Any help will be greatly appreciated.
3 REPLIES 3
Hi @saclovitzky
Problem starts when panel coordinates exceeds story levels. You can set story for selected object(s) in Object Inspector.
Krzysztof Wasik
@Krzysztof_Wasik thank you very much for your reply. Pls. see attached, I select the wall(s) for a specific level but I have this warning messages. If I ignore these messages, Will the result be affected(pls. see attached screenshot)?
Hi @saclovitzky
This warning reflects your model geometry and stories definition. If you would like to avoid it you can divide panels along stories levels. Static analysis results shold not be affected by this warning.
Krzysztof Wasik
