selection of walls to Story
saclovitzky
saclovitzky
In creating story levels, I'm just wondering why some of the walls are left out.
Is there a way to include them afterwards.
Pls. see attached screenshot and file regarding my queries.
Any help will be greatly appreciated.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @saclovitzky
Problem starts when panel coordinates exceeds story levels. You can set story for selected object(s) in Object Inspector.
Krzysztof Wasik
saclovitzky
@Krzysztof_Wasik thank you very much for your reply. Pls. see attached, I select the wall(s) for a specific level but I have this warning messages. If I ignore these messages, Will the result be affected(pls. see attached screenshot)?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @saclovitzky
This warning reflects your model geometry and stories definition. If you would like to avoid it you can divide panels along stories levels. Static analysis results shold not be affected by this warning.
Krzysztof Wasik
