Seeking Any Advice: Dynamo for Buckling Coefficient & Load Combination Creation in Robot
JynNg
JynNg
Dear,
I come before you with a query that requires the finesse and expertise of those well-versed in the intricacies of Dynamo and Robot.
In my pursuit of knowledge, I seek guidance on two specific fronts:
  1. The acquisition of the buckling critical coefficient from Robot utilizing Dynamo.
  2. The meticulous process of creating load combinations from pre-existing load cases.
🌟 Your guidance could illuminate the path for many, including myself. Let's collaborate and elevate our collective knowledge!
Thank you in advance for your invaluable assistance!
Warm regards,
Stephane.kapetanovic
hi @JynNg
you can get help through the approved solutions on the forum, for example by searching for API and Python.
Other languages exist such as C# and VB, you will be able to adapt your code to your use.
Note that you also have files and example delivered with the SDK located in the installation subdirectory ...\SDK.
You can also find information such as the API tutorial, videos (1, 2) and useful addins already developed and the app store.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
see also
conbination
https://forums.autodesk.com/t5/robot-structural-analysis-forum/python-load-combinations/td-p/9064034
buckling
Steel design - CodeParams
Steel design report
[API] Define Membertype Adjoin Params
2025:
Dynamo for Robot Structural 2025
