Hi Autodesk
I have a problem with the file that I have attached.
When I run the RC design it will work except for one panel number 1; it states that "A problem has caused the program to stop working correctly. Windows will close the program and notify you if a solution is available"
It works fine for all other panels checked yet this happens every time panel 1 is selected. I cannot find any thing unusual baout it so if possible could you review and see if there is something that I have done incorrectly?
Many thanks Patrice
Solved by Artur.Kosakowski. Go to Solution.
Somehow the thickness label assigned to panel 1 has been erased from the dialog. Try to define a new one (or assign one of the existing) instead.
