241 Views, 2 Replies
Run error
Hi Autodesk
I have a problem with the file that I have attached.
When I run the RC design it will work except for one panel number 1; it states that "A problem has caused the program to stop working correctly. Windows will close the program and notify you if a solution is available"
It works fine for all other panels checked yet this happens every time panel 1 is selected. I cannot find any thing unusual baout it so if possible could you review and see if there is something that I have done incorrectly?
Many thanks Patrice
2 REPLIES 2
Artur.Kosakowski
Somehow the thickness label assigned to panel 1 has been erased from the dialog. Try to define a new one (or assign one of the existing) instead.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Thanks Artur, I did that and it worked fine!
Technology Administrators
