axial load results seems unaccurate
Hi
I was checking the axial load of two columns one is on the top of the other.
the one on the top should have a lower axial load then the other. which based on Robot results is is not.
seems to me the all ground floor columns carriyng less load than the ones on the top! which didn't make sense
Any one can help me in this?
Regards
File is attached
Artur.Kosakowski
Autodesk Support
Autodesk Support
Which bar numbers and load case to check?
Artur Kosakowski
all of them!
1- 25 and 165
2- mainly 119 on the ground floor and the one on the vicinity number 7
you can see also 19 and 108 those are on the top of each other.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you confirm that the supports are on the right level?
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
OH YES....I designed the first floor first ...then added the basement ...thought load will be transfer...but it wasn't...thank you Artur...as always..very helpfull..
