Robot API: Number of calculation points
Dear all,
I'd like to modify the number of calculation points during a Steel design calculation in my API script. Is there a simple way to do this that does not require any work-arounds like using characteristic points?
Thanks for the help in advance!
Best regards,
Marcell
Romanich
Hi @Anonymous,
Maybe this macro will help you to find how to do it
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-for-member-verification-uls-ratio-along-bar-length/td-p/5873614
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Hi @Romanich,
Thanks for your answer!
I have seen and used this macro before. Unfortunately this solution introduces characteristic points along the bar length and gets the utilization ratios in a for loop over these points .
As I said, I would prefer to avoid this work-around and introduce simply a number of calculation points in my API script.
I'm trying the following code:
Set RDMAllRes = RDmEngine.Results
Set RDmDetRes = RDMAllRes.Get(currentBar.Number)
Set RDmEffDef = RDmDetRes.EffDef RDmEffDef.WriteParam I_DEDPT_POINTS_NUM, 10
But it doesn't quite do the trick.
Best regards,
Marcell
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I think You should use IRDimCalcConf.NPointsNum
Rafal Gaweda
Hi @Rafal.Gaweda,
Thank you! That was exactly what I was looking for. It is actually very well described in the Robot Steel API guide.
Best regards,
Marcell
